Lattice Structure from Physical Model
I have a plastic lattice model (see image) that I need to recreate in Rhino. I’m not sure how to start. The physical model is malleable and flexible. I was able to create the overall structure in Rhino but it’s FLAT (see image). I need the create a rhino model with the same overall curvilinear shape as the physical model.
My first thought was to create a grid of curves and then move control points to later sweep. Unfortunately, moving control points changes the length of the curve. If anyone has advice, please help.
I’m not familiar with Grasshopper but I’m willing to try.
This can be done with Grasshopper and Kangaroo.
Here’s a post of @DanielPiker with a simple example of one bent strip.
Your object looks like a scissor structure. Again a simplified example:
You can find many more examples using the search function…
