Max3
(Max Allstadt)
June 23, 2020, 6:00pm
1
I installed WIP 7.0.20168.13075, 6/16/2020, and now the _InsetEdge command will run but when I hit enter it doesn’t do anything.
Anyone else having this issue? It’s a very simple object. Just trying to insert an edge between the two highlighted loops shown here:
theoutside
(Kyle Houchens)
June 23, 2020, 6:21pm
2
Working here in Work In Progress
(7.0.20174.13515, 6/22/2020)
Commercial
try box mode, does it work there?
Max3
(Max Allstadt)
June 23, 2020, 7:57pm
3
Not working in box mode. Will try with newest WIP
inju
(Inju)
June 23, 2020, 8:17pm
4
Work In Progress (7.0.20168.13075, 16.06.2020) Commercial
InsertEdge it’s working.
Max3
(Max Allstadt)
June 23, 2020, 8:57pm
5
Now I’m wondering what it is about this object that could’ve broken it. Very simple object.
Maybe I need a toolbarreset.
theoutside
(Kyle Houchens)
June 23, 2020, 11:54pm
6
that won’t do anything to fix a broken tool, only a missing one. what version are you running and can you post the file?
Max3
(Max Allstadt)
June 24, 2020, 12:00am
7
It’s just this silly little soap dish a client wanted for a prop:
Soap Dish.3dm (240.0 KB)
“About” =
Work In Progress
(7.0.20168.13075, 6/16/2020)
Commercial
The insert edge and insert point commands both fail. I was attempting to insert an edge between the two widthwise edge loops.
theoutside
(Kyle Houchens)
June 24, 2020, 12:15am
8
check for updates and get a newer cut of v7-
inju
(Inju)
June 24, 2020, 9:17am
9
You created a model with errors.
Fixed model:
Soap Dish1.3dm (190.1 KB)
“About” =
Work In Progress
Commercial
Max3
(Max Allstadt)
June 24, 2020, 12:20pm
11
What were the errors? I couldn’t see anything weird in the original except for one doubled up crease. Taking the creases all out of the original didn’t make insertedge work.
inju
(Inju)
June 24, 2020, 12:40pm
12
I put you a corrected model, I think you can compare.
I don’t speak English well.
Max3
(Max Allstadt)
June 24, 2020, 12:53pm
13
So my problem was just one extra edge loop on the bottom, which looks slightly inset in smooth mode, but was overlapping the creased outer edge in box mode?
Is that all you changed?
I deleted it in the original and it fixed my problem. I also tried using shift-scale with gumball to shrink that edge loop inward and it also fixed the problem, without deleting. I don’t get why it was a problem though.
@theoutside Was this a coincident vertices problem?
inju
(Inju)
June 24, 2020, 12:56pm
14
If the model is correct, then there is no problem.
Max3
(Max Allstadt)
June 24, 2020, 1:10pm
15
Thanks for fixing it. I think there’s a problem with the SubD interface when something that breaks the model does not look like a problem.
inju
(Inju)
June 24, 2020, 2:21pm
16
An example for a soap box, I do not see where it is possible to make a mistake.
theoutside
(Kyle Houchens)
June 24, 2020, 3:10pm
17
that’s the good/bad thing about SubD here… it doesn’t “break” like tsplines used to.
that’s why you will constantly hear me say over and over …
“model in box mode, evaluate and refine in smooth mode”
if your box mode has problems they amplify in smooth mode.
