Hello why these commands are not out of trial because we need them TestSubDSplitFace,TestSubDSplitEdge
@BrianJ
These test commands still run but do not autocomplete in the WIP. InsertPoint allows splitting of faces now. Can you explain what you use the split edge test command for? I can see if InsertPoint could also be used for that.
hi yes InsertPoint can split face of Subd …but it cannot add point to edge(split Edge) in SubD(only add for mesh object)
Hi @BrianJ
@pascal
!! Subd
When we execute the command, an extra vertex is created.
insertpoint.3dm (82.2 KB)
