Is there a way to extract the contour lines from terrain as Rhino curves? I’d like to bring the line work into my illustrator file. Thanks!
Hi Ryen,
If you explode the terrain, you will get the resulting mesh and 2D contour lines of it. (You can make a copy in place to do not lose the original terrain).
If you want to get the curves or points used to generate the terrain, you can use the _laExtractCurves command for that.
This is exactly what I was hoping for. Thank you so much Francesc!
