Labels for components?
Is there a way to show the components’ labels/names, like this?
this works well.
Thanks! Found “bifocals” but not this… cheers
Sun glasses probably won’t do what you want in this case:
The way I typically do it is to put the slider into a Group and just type in the “topic” as the name of the Group, like so:
If you Right Click on the Group and select Color, you can even make the Group invisible and so only the text will show:
Results in clear and clean:
// Rolf
Thanks Rolf-
Actually, looking into Sunglasses a bit more, there’s an option to “Display nicknames” - seems to do the trick!
Oh hang on… just found we can label some of the components themselves (with multiple inputs/outputs I guess) by right-clicking on input/output.
Is this bad practice?
labels
Yes, bad practice based on my own early experiments with GH conventions, renaming standard components is a bad idea. Much better to limit custom naming to inputs and outputs, and clusters of course. OOPS! Sorry, that’s exactly what you are doing. DOH! Yes, good practice. :sunglasses:
Sunglasses is WAY BETTER than Bifocals and doesn’t impose itself on GH files with invisible labeled groups as Bifocals does.
I hope this is in line still with this thread but is there a way to label the line items in a panel?
No. You can associate another panel with labels for the indices for display purposes, but the lists are purposefully numbered.
