Keyshot (11) Plugin does not work in Rhino (7)
Hello :slight_smile:
The Plugin shows up, but nothing happens.
It even says the command is not known.
Is it because both Versions are too new?
Here the System Info:
Rhino 7 SR23 2022-10-9 (Rhino 7, 7.23.22282.13001, Git hash:master @ a931168ca9426920ae6aa97218710b662f17fc39)
License type: Commercial, build 2022-10-09
Windows 10 (10.0.19042 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 2-18-2022 (M-D-Y).
Primary OpenGL: NVIDIA Quadro T2000 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 4-4-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 473.34
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-4-2022
Driver Version: 30.0.14.7334
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\KeyShot9RhinoPlugin (ecfe8d1f-876a-460f-aa5e-3dd816936811)\1.4.0.0\KeyShot9RhinoPlugin\Rhino 7\KeyShot9RhinoPlugin.rhp “KeyShot9RhinoPlugin” 1.4.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.23.22282.13001
BR/Sebastian
Hi -
You might want to check the KeyShot forum - Discussions : KeyShot
Hey Wim,
Good Idea, I will share the results here once I know whats going on.
BR/Sebastian
I got the solution, Luxions (Keyshot) support was really supportive to solve that issue.
My Ressource Folders in the Regestry Editor were located on folders that are not locally stored, but on my One Drive.
Keyshot does not like that. So changing those to a local value did the trick. (Computer\HKEY_CURRENT_USER\SOFTWARE\Luxion\KeyShot 11)
The Reason Rhino said “unknownCommand” was due to the wrong version of the Plugin that I had installed (9 instead of 11).
So there were 2 Reasons for that not to work, nothing to do with Rhino as Wim already predicted.
Hope that helps someone esle who is running into this issue.
BR/Sebastian
Buenas tardes
Al acabar de diseñar un modelo en Rhino7, y ejecutar el comando KeyShot11Render, no me abre el programa KeyShot… pero sí me aparece en la barra de comandos como que se ha ejecutado el comando. He leído los comentarios, pero no me termina de quedar claro cómo solucionar el problema…
Un saludo
Hi Julio,
I hope i understood your message correctly, have you tried using the solution the message before? For me the issue was the Ressources Folder, and that it was stored on a cloud folder- is that the case?
BR/Sebastian
I required keyshot 11 plug in for rhino
Is there any one help me?
Hi @Amit_sahu
Luxion’s plugin for Rhino can be downloaded from their website:
HTH, Jakob
