Keep Seeing Object Edge In Renders
Even though I set edge thickness to zero in viewport properties for rendered view I keep seeing lines for object edges in rendered view like so. I don’t want them, what do I do?
In the viewport properties panel uncheck the edges and wires.
I don’t see that option in the viewport properties. But I have unchecked every edge thickness option in display modes for rendered view.
The command to get to the properties I am talking about is _DisplayProperties.
On the Mac it looks like this.
On Windows you can get there through the panel menu, select Display
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#user_interface/panel_options.htm
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#commands/displayproperties.htm
Uncheck the edges and wires.
Yes, they are not checked. Sometimes it shows the edges, sometimes it doesn’t when I zoom out.
Please share the file and the result of the Rhino command _SystemInfo
Rhino 6 SR18 2019-9-23 (Rhino 6, 6.18.19266.14201, Git hash:master @ 3d84f88dec99b2f4e8b7497e739ed2adc2ba8ef6)
License type: Educational, build 2019-09-23
License details: Cloud Zoo. In use by: dceltikc ()
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: MSI
Hybrid graphics system.
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 2-3-2022 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 1-17-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 417.77
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-17-2019
Driver Version: 25.21.14.1777
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.18.19266.14201
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.18.19266.14201
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.18.19266.14201
C:\Users\defne\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino6.Plugin.dll “Enscape.Rhino6.Plugin” 0.0.21349.1646
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.18.19266.14201
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp “V-Ray for Rhino”
truncating cut.3dm (342.7 KB)
Hello- your file looks ok here - that is, no edges showing if these are off in the display mode settings. I see yoou NVidia driver is quite old, I’d get the latest from the NVidia website and see if that clears anything up.
… also, I don’t know of any good reason for not being on the most updated version of Rhino 6, which is 6.35.
Rhino 6 SR35 2021-8-10 (Rhino 6, 6.35.21222.17001, Git hash:master @ 073ac7b225c67348731c6597127b9410126c3139)
License type: Educational, build 2021-08-10
Windows 10.0.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: MSI
Primary OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 9-12-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 517.40
> Integrated acclerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 9-12-2022
Driver Version: 31.0.15.1740
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.35.21222.17001
I have updated both NVidia drive and rhino, but still having the problem.
