指令: _Grasshopper
vvvvvv Do not worry about the error message below! It only indicates that Speckle is not installed on your system and that the Karamba3D Speckle export-component can therefore not be loaded.
An error occured during GHA assembly loading:
Path: C:\Program Files\Rhino 8\Plug-ins\Karamba\SpeckleConnector.gha
Exception System.IO.FileNotFoundException:
Message: Could not load file or assembly ‘Objects, Version=2.20.1.16205, Culture=neutral, PublicKeyToken=null’ or one of its dependencies. 系统找不到指定的文件。
Exception:
“Tekla.Structures.ModelInternal.DelegateProxy”的类型初始值设定项引发异常。
at Tekla.Structures.ModelInternal.DelegateProxy.get_Delegate()
at Tekla.Structures.Model.ModelInfo.GetInfo()
at Tekla.Structures.Model.Model.GetInfo()
at Tekla.Structures.Dialog.UIControls.EnvironmentFiles.get_files()
content from: “C:\Program Files\Rhino 8\Plug-ins\Karamba\karamba.ini”
uf: “C:\Users\Administrator\AppData\Roaming\Karamba\karamba.ini”
