Hello
I am trying to model a structural system that uses the walls and floors to work in unison. A performed a simple test of how karamba would model this and I got the following result below. I have four supports at the outermost bottom points of the the walls with pin supports in all three directions. There are no other supports in the model. However, the walls do not translate/deform with the slab as expected. I would be expecting to see a perfect (visually at least) hanging wire kind of shape, but the walls corners do not translate. Is there an obvious mistake with fixities that I’m missing? Code attached. Thank you!
WallSlabConnectivity_30_07_2024.gh (93.7 KB)
