Hi everybody,
within my thesis I am working with compression only structures and I decided to analyze some of them as shells in Karamba. However, I obtain some negative nxx and nyy, although:
- the mesh geometry I input for the shell is derived from a compression-only form finding method (so should not lead to tension)
- I used the new component for defining the concrete properties and I set the tensile strength to be equal to zero
- I do not have any reinforcement
Still I get some tension forces. Can someone explain me why or how I can fix my model to obtain an only-compression structure? Any help is really appreciated!
Thank you,
Caterina
