Hi all,
Is it possible to obtain data in Karamba that represent the axial load test of a structural object? I’m planning to compare between the FE simulation results in Karamba and an actual test by creating a chart like this below:
There is no one click method to obtain this graph, but you can simply extract the results from different calculations and plot them into a graph using excel or grasshopper tools.
Thank you for your reply. Can you please let me know what parameters should I change to obtain the required data? I mean the input and the corresponding output.
Thanks.
