Joining two surfaces with a gap between to a closed brep
Hello everyone, I’m a bit stumped at the moment and can’t get any further. I have two surfaces that are almost on top of each other and I want to create a closed brep. Actually I thought it should work with the loft component and brep join, but I can’t get a brep to work, can anyone help me?
ImageSampler2.gh (40.5 KB)
VG Tim
You could try something like this.
You can not directly loft your edges because they dont form a path to loft a surface through
I added a tiny offset to the bottom of your surface so there will be some volume.
Thank you, even though your solution didn’t work for me, it gave me an idea. I also moved the bottom surface slightly to get volume, then simply created a surface between the edges.
FYI,
