Joining/ linking up meshes
#1
Could anyone give me some ideas for joining two meshes, possibly via linking vertices?
They way I thought might work is to convert to nurbs then add a surface intersecting both, then convert to mesh again?
Weaverbird has a wbjoin command but I’ve not used grasshopper yet. Is this a good option?
Many thanks again (again) for your help,
John
(Wim Dekeyser) #2
What is your goal?
In Rhino, you can join meshes even if they are miles apart. That will create 1 mesh object and is often used to reduce file size.
#3
The idea is to be able to print them out as one object. One mesh being inside the other, I assumed they must be “attached” to each other in some way…?
Thanks.
#4
I think you want to merge them together. Try MeshBooleanUnion Command This will melt them together. if Both Meshes are Closed then this will also create a “WaterTight” object
If you want too merge other objects than meshes use BooleanUnion itself instead of MeshBooleanUnion
(Wim Dekeyser) #5
Also, when it comes to printing, @Willem replied to your other question here. Most likely you won’t have to Boolean them together.
#6
Thanks Jordy and Wim,
Thanks also to @Willem, although this is really a different question.
What I want to do in this case is print a mesh inside another mesh, and I was just wondering (for the sake of structural integrity rather than actually getting it to print) whether it would be best to link the two meshes together.
Conceptually, I effectively want to print a round mesh “hanging” inside a larger round mesh - how would I create the supporting edges between the two?
Many thanks again,
John.
#7
For rendering it is needed some times too - for example a glass sphere with a thickness. Simple _join the two meshes and they are handled as one object. Best check the surface normals before if needed for the final result.
(Wim Dekeyser) #8
sounds like you just need to draw a few lines from a few of the vertices of the outer object to closest vertices of the inner object. then either pipe or apply curve piping and mesh/extract render mesh.If you want smooth transitions you should look into grasshopper and its plug-ins. (or t-splines)
#9
meshes can be joined to one object without an additional visible connection, simple use _join
(Wim Dekeyser) #10
That’s what I answered a bit further up but apparently we are talking structurally connected here.
#11
Thanks to you all, and especially to wim.
