I have two scanned files of a shell, one is the outside and the other is inside, I would like to join these two drawings together to make one drawing of the shell.
I have been reading some of the similar questions and I have been unsuccessful so far, I am still very new to CAD
Hello - are the shells aligned? If you import them both do they already end up in the right places? That would be a start, but what are the scans? Points/PointCloud? Meshes?
Hello - and is the goal to make a 3d print? i.e. we don’t need to worry about reverse engineering the mesh to surfaces, we just need to align the meshes and close off the edge, leaving the whole thing as a polygon mesh - am I on the right track?
Hello - I guess the details depend on what you’ve got… I can imagine a couple or three ways to get the meshes aligned - all of them somewhat tedious… if you can zip and upload the files to www.rhino3d.com/upload, to my attention, I’ll have a look and see if anything useful comes to mind in the way of a workflow. Please include a link back here to this topic in your comments…
Hi Andrew - it’s hard to see from here how the two parts are meant to align - I see that there is a planar or near-planar cut on both - are those the same plane, in theory? Knowing that would help get things started at least…
Hi Andrew - see the attached file - this might be one way to work, to get things positioned.
Using History, Project some lines onto the meshes - these projections will be ‘live’ section curves that will update as you manipulate the two meshes, showing their relationship at these locations.
