I am having trouble lofting a number of closed curves. It seems that the sequence of the closed polylines are not in the order that they are supposed to be. Se pic below.
it is supposed to be a bridge along 3 given lines. in the grasshopper file i tried to import a photo of the cross-section that explains the input for the number sliders.
This has never been an issue with other closed curves.
The list placement of the curve/curves that are in the wrong Place, vary depending on how many cross-sections i set it to make(number slider “Inndeling av line”).
So i do not know how to set the curves in the right order. I do not understand why this happens, this has not been a problem before.
Smart ways?
When if your naked boundaries are not planar, Cap Holes won’t work.
Try to find naked boundaries → use Edge Surface or Fragment Patch or whatever to seal individual boundary —> Join them all together
