Hello
I want to join hexagonal faces.
It’s not join faces when I revolute curve.
Does anyone know how to fix it?
Hexagonal revolution srf.gh (16.0 KB)
Hello
this is classical problem that explain why I did this little tool in Nautilus plugin
But it will not work well for some geometry (sphere …) which lead to very small hexagon
See also this discussion there are other tools
(sphere …)
Hexagon On Surface
It is possible to flatten the extremities
Hexagonal revolution srf LD.gh (22.8 KB)
Thank you so much!
I can’t use Nautilus plugin because I use Rhino(ver.6).
I tried using the data you provided, but it ended up looking like the image.
Will Nautilus plugin solve the problem?
If I solve it, I want to update Rhino(ver.8) right away!
Look at the link i provided there are surely solutions that work on v6.
Oh Sorry.
I didn’t realize you could see past posts because I used this community for the first time.
Thanks to your help, I think I can do it.
I’ll try the challenge.Thank you!!
