i m new to this forum and also learning grasshopper and i seriously need help in this… how do i join surfaces in grasshopper…firstly i created a quad ball from rhino then from grasshopper selected the surfaces but seems like there are gaps between the edges and when i apply hexgrid they appear in different surface i want them to appear smooth in all surfaces… please help
honeycomb on surface.gh (4.0 KB)Please do not double post. If you are wondering why you get no answer, see here: How to ask effective questions
Specifically point 3
thank you for the correction. i have attached gh file on my post honeycomb on surface.gh (4.0 KB)
Each Rhino NURBS surface has an associated “render” mesh which is used to display the surface. If this mesh is too coarse then there may appear to be faceted gaps along the edges even though the edges a smooth and match other edges. The solution is to increase the resolution of the render mesh. One easy way is to go to Options > Mesh > Custom > Detailed controls and set the “Minimum initial grid quads” to a value such as 5000 or 10000.
For more information see http://www.hydraulicdesign.net/meshes.htm and https://wiki.mcneel.com/rhino/meshfaqdetails
thank you…i have done the mesh setting but actually i want that to happen in grasshopper the hex grid is not appearing continuous in grasshopper
after creating the quad ball in rhino>selected surface from grasshopper but there are four surface and hex grid is appearing different in all the surface. i need only quad ball sphere since other type sphere when apply grid…the grid get concentrated from a point
Could you change the title of this thread, it’s a bit misleading.
What name you want?
Tim, are you planning to follow me on every thread looking for a fight?
The thread is about visual gaps due to quality of the mesh and not about ‘physical’ gaps between the surfaces.
@ivelin.peychev calm down. I never offended you or whatever, just because I disagreed with you once!
I was serously asking, because I can rename threads …
Oh, I am a very calm person, but I don’t let any provocation pass by. I always fight my own fights, it is however not benefitial to this forum.
When I make a comment there is aways a reason why, if people can’t see it they should look for a problem within them.
If you have such comments from now on please send me a private message instead of ruining another thread, like the previous one which got closed by David.
I didn’t ruin your thread. I made one comment and just told my opinion. Not offensive, or anything, I just disagreed with you.
Somehow ironically, that you ruin this thread with your attitude the whole world is against you. I also commented constructively on your other threads. So I really don’t know what problem you have with me, nobody else had on this forum before. And whatever I did to you, I’m sorry
And I think you still have not understood it. My question was meant seriously because I have the ability to rename threads.
But one must be the wiser, so I’ll just ignore you in the future if you can’t talk to me on an objective level.
ok visual gaps it is …how do i improve that? i improved that in rhino but grasshopper i still creating grids on different surface of the quadball and problem is not solved. grasshopper should identify the quadball as one object and create grids uniformly but instead it changes after edges which i think is a gap, as you can see in screenshot 2 or gh file
yes i did that too… what i meant is the hexagrid which i want it on quadball sphere is not appearing uniformly since there are four surfaces making the quadball sphere the grid is appearing different in all four
It won’t ever work the way you intend with seam matching on those quad ball nurbs patches. If you want a uniform sphere of hex you are better off using a mesh and Ngons.
Can you upload an example model, I tried with sphere but I don’t get any gaps.
It is also possible that it’s a video driver issue, or video adapter issue.
yes even me i am able to do that but once i make changes to the form that is converting rhino surface to tspline and making changes to form desired shape and again convert it back to rhino surface. grasshopper not able to make the form as one surface and apply grid uniformly
