II drew a line then added to the line using the osnap so the lines were connected.
Then after I run the Join, the command line says “2 curves joined into one open curve.”
then when I select to see if it worked then I have duplicate line segment, not joined.
i run seldup to get rid of the duplicates.
I am trying to join these lines and can’t get it to work.
I just feel like I am going in circles or should I say curves.
I did this earlier and worked as expected.
my goal is to run csec to make a solid body. which I did in another file, no problems, but I needed to add a tail and now I can’t get it to work.
