Hello All,
thanks in advance
I am a new rhino phyton developer , how i can start , we need to automation for jewellery designs
like rings, earring, pendent etc
Regards,
Ram Gurav
(India)
Hello All,
thanks in advance
Regards,
Ram Gurav
(India)
“How can we start?” No one can answer this question definitively, as it depends on various factors.
By the way, if you are familiar with Python and Rhino, you can make a little progress in it. However, if I were to start this task, what I would do is just create the structure of, for example, a ring that is made from different parts. Then, I would write some scripts to handle different designs and apply them to the base structure. In a more modern but challenging approach, I am going to create a database of existing rings and then write a script to make that data work with Grasshopper.
Hi
I could make the same question
I want to fly, where to start?
Hi @Ram_Gurav ,
I’m the lead developer of VisualHull.eu and I’ve helped many design studios and manufacturing workshops automate their workflow.
In case you need guidanance and concrete work towards automating your entire workflow we could schedule a meeting, I would love to help you reach your goals.
My portfolio : https://www.youtube.com/channel/UCuzuZ22bHOSt_H0LS1iID_A
In case you need custom software to automate tedious tasks and drastically reduce the workhours per job don’t hesitate to reach out to me farouk.serragedine@gmail.com.
Farouk
