I am trying to reproduce the examples found here in order to get a basic understanding of rhino compute with Javascript but I keep getting the error “Uncaught ReferenceError: rhino3dm is not defined”. I even tried it as it is here but I still can’t get it to work. Any help is greatly appreciated, thanks!
The codepen example works for me. Can you share a code sample that can re-produce the issue?
The samples have moved around some. Here are some you can look at: https://github.com/mcneel/rhino3dm/tree/master/docs/javascript/samples
