Any live examples of Rhino.js
I can see there are some examples here but are any of them available to see live?
I’m looking for a framework to build a webapp that processes meshes, some key functions would be:
  • Generating curves based on meshes
  • Mesh modifications, solving intersections between planes and meshes - for example.
  • Import/export 3D file.
Would Rhino Compute be a viable solution? If not, does someone know of an alternative?
Here are a few:
https://files.mcneel.com/rhino3dm/js/latest/rhino3dm.html
https://files.mcneel.com/rhino3dm/js/latest/rhinologo.html
To get an auth token, go here:
https://www.rhino3d.com/compute/login
Hopefully. Rhino.js is pretty and there is a lot left to expose.
– Dale
Brilliant.
So, the key pieces are: rhino3dm.js, the wasm, and the compute server.
What roles do each play, particularly the wasm piece?
Hi @greg.burgreen,
Basically:
1.) The wasm is openNURBS build as web assembly.
2.) rhino3dm.js is the JavaScript interface into the wasm.
3.) Rhino.Compute is only required for access to functions not found in openNURBS.
– Dale
Hi Dale,
For larger applications, will DocObjects be stored locally or on the Rhino.Compute server?
Greg
Hi @greg.burgreen,
Rhino.Compute only provides computation services - it won’t serialize any objects.
– Dale
