I tried to bake my revit structural steel framing/column element to rhino using RIR and elefront but when I do this, it only bake the analytic lines but not the physical steel element in rhino. Other revit elements like slab, roof and others bakes well inside rhino but steel framing and column it doesn’t, I am wondering maybe because they are revit families that are created by a sweep path by profile and not a solid geometry?
Any help is pretty much appreciated.
Good day, please see attached gh file for review.
It seems like, only the analytic lines that bakes, there
must be something missing or error on my script.
I really do appreciate your help :).
Good day and thank you for your helpful response, it works now! and my next question, is there
a way to create definition wherein you can bake the element in rhino from revit
and at the same time assign/create a layer for it automatically?
