I’m new to grasshopper and I’ve been trying to loft these curves together but its not exactly following the curves. Can someone tell me what’s wrong or is there is an easier way to loft them?
hypar attempt 2.gh (17.6 KB)
You can use Edge Surface instaed of Control Point Loft, and fyi.
Control Point Loft Grasshopper Online DocumentEdge Surface Grasshopper Online DocumentThank you, I’ll keep those docs in mind. But while edge surf works I don’t want it to peak at the top… I’m trying recreate the look of a table so I need the top flat… Is it because of the way I’ve scripted this that it’s peaking? (I know it’s probably the longest possible way to do this).
Regarding this requirement, could you provide a reference image? The method I mentioned earlier was merely a solution to fix “Lofting errors”
You can achieve it with Network Surface, and fyi.
Network Surface Grasshopper Online DocumentNetworkSurface.gh (19.1 KB)
Yes! Thank you so much, I really appreciate it
