Dear Karamba developers,
I´m playing around with your Cross-Section Properties component to figure it out how to use angular cross-sections TestCroSec2.gh (48.9 KB). In particular, I´m trying to customise a pre-existent CS and follow what it is said in this post.
Unfortunately, I´ve found two inconsistencies:
The Section Modulus (W) seems to be flipped in Disassemble component output. According to EuroCode3 (EN1993-1-1:2005), Wely and Welz correspond to the elastic section modulus about principal (strong) and secondary (weak) axis, respectively. However, they seem to be reversed. Please, compare the manual results (in red and blue group boxes) with the values obtained from a disassembled “T” CS provided by your CS Range Select component (gray group box).
The Modify Cross-Section component apparently does not update all W outputs properly. While Wely+ is updated, Wely- is not. Something similar happens for Welz- and Welz+ outputs.
Please, would you confirm whether am I right or not?
Do such these inconsistencies affect Karamba analyses? I´m particularly interested in EC3 related components, e.g. OptiCroSec or Utilization.
PS: I´ve verified that CS properties for the first row angle profile in this table match those computed with your CSProps component.
PPS: My Karamba3D version is 2.2.0.11-220214 for RHINO 7
