Issue with Make2D, Anemone and Clusters
Hi!
I am using Rhino 6 + GH, and am trying to use Make2D and Anemone inside a cluster to create an exploded axonometric. The issue is that the loop is only working when I open the cluster and not outside…Why might this be?
Thank you!
Tejas
Anemone dose not work inside clusters, I know that much.
The reason is simple. Anemone loops the solution and records, clusters only solve the solution one time (like all gh components) so each time anemone would essentially start from its beginning.
I haven’t tried it, but have you tried the fast loop in anemone since it executes after all loops are done?
Yes, Fast Loop can do it, I have tried it.
