Hi, I just created a definition for a cone that follows a polyline. It works fine but when I put it inside a cluster, the output is different than what is inside the cluster.
In the first image, I am inside the cluster and the surfaces are clean and smooth, but in the second image, once I close the cluster, some of the surfaces are skewed). Anyone has any idea why that might happen? It has happened to me again once or twice in other clusters.
Most likely because the last time I checked, Anemone doesnāt run inside of a cluster?
Are you referring to the twisted sections on the right, baked from outside the cluster, vs. the straight sections on the left, baked inside the cluster?
I spent too much time brutally hacking away at your code, trying to do it without Anemone before understanding what that loop was doing. Some things are simpler and ābetterā (to my eyes), some of your code was left in place. The result isnāt terrible but could be better with seam alignment, as you did.
Iām going to quit for now, sleep on it and maybe get back to it later. Your code is pretty cool, if only Anemone worked inside of clustersā¦ KinkyCone_2022Oct14a.gh (35.2 KB)
Later - OH NO! I canāt believe I did this. I spent considerable time cleaning up the file as shown in the screen image but apparently didnāt save it. Will try to do it againā¦
UPDATE: Re-did the cleanup, hereās the correct file (I hope). Donāt know how that happenedā¦ KinkyCone_2022Oct15aa.gh (24.8 KB)
P.S. Unfortunately, due to internal flattening, this fails to handle multiple Start/End radii. If it did, it would be easy to add thickness to this kinky cone by creating two on the same guide curve. Oh well.
