Issue with Dim: Chain alignment
Hi there,
Just wanted to know whether there’s an option to prevent or fix the following when using Dim.
It’s hard to explain in words, but basically, I want to make dimension chains look like on the right, but when I use Continue Dimension, it keeps on creating long handles like in the left. The cumbersome workaround involves ortho smarttrack for each point. Is there a way to keep the dimension leader always limited to a set distance from the number?
-Jeremy
One option is to suppress the dimension lines:
If you’re after a certain look that doesn’t have the dimension lines suppressed, you could use this workflow:
Hi Jeremy -
Yes, use the Fixed length extension option in the annotation style:
FWIW, moving the control points of dimensions will break the history on those objects.
