This comes from a longer definition and after several definitions attempts without success. I found that probably (maybe) the best option to generate a mesh to fit the closed curved (in green) would be starting to generate a surface with the Patch command, but in this case it is not working as expected as it is not generating the blue area (dashed):
Hi @martinsiegrist, thank you for your time. Your suggestion works great, however for this case I need to find a way to avoid the need to introduce section curves and I am not able to ignore some points. Actually there are some situations where I have arcs at the both upper parts of the closed polyline.
I thought that maybe minimal surfaces with Kangaroo could be an option, but I have no experience with it so any advise/ comment if it feasible would be great to have.
