Issue Import shapefile using Urbano
Hi, I am trying to import a shapefile that I modified using QGIS into Rhino using Urbano’s Import Shapefile Features. However, I am getting the following error message:
Any idea what is going wrong here?
E: These are the files in question (https://we.tl/t-1Qez2aBf1J)
Hi -
No idea, no. It looks like that plug-in was recently updated so you could try to reach the author by using the support eMail address on the F4R page.
You could also check if any of the other plug-ins on F4R that read Shapefile will correctly read this one.
Same problem here! Some shapefiles are accepted and for some other shp files I get this message. Anyone found a solution?
