Isotrim mesh?
hello
in grasshopper you can isotrim a surface to create a grid like set of lines with the help of divide domain square command. can you do the same or similar to a mesh? connecting isotrim to mesh gives an error ?
is this possible to do ?
Hi.
If the mesh is planar, you can get the boundary naked edges first. If it is not, you have to convert it to a surface.
mesh_isotrim.gh (5.7 KB)
is it possible to convert mesh to a “surface” ?
Hello
You could isosplit a mesh you just have to put a weight at each vertex
could you provide an example
Just search !
https://discourse.mcneel.com/search?q=mesh%20iso%20split
