Trying to track him down about a bug in his Project Timer app, hoping to touch base with him.
I think he escaped the labyrinthâŚ
You are looking for @ThomasAn . His last post was 4 months ago so he seems to still be active here.
-Willem
The last line of that message says that Windows is not giving the program permissions to read or write in that folder.
Yeah, and I donât know why, because it is writing the file, and I do have permission to write to that folder. I donât know if it is because it is a network path or a windows 10 issue. I would be willing to troubleshoot the problem, if you donât mind releasing the source code.
Hi Thomas,
Good to see you still around. Not to change the subject, but I recently had a long running Timer crash for some reason and when I re-opened it all data was wiped out. I opened the .ini file and it too was empty after the4 crash. Is there any other place a backup might get saved? I usually open the ProjectTimer.ini file and copy the week or month range of data and import that into Google Docs or Excel to work up a billing invoice and just let the timer runs for the duration of the project, about three years in this case! I know I should be letting the Timer write timestamps but when I have lots of categories that gets pretty involved. Great tool and this is the only time Iâve had any data loss with it. Not even sure why it crashed in the first place. The lesson Iâve learned it to maybe not let it run forever and clear out at each months invoicing. Any hints of help you might have would be greatly appreciated.
Jody
Sorry guys. This app was written in 2007 on a Windows XP on Visual Basic (I am surprised it still runs today). I donât have access to the code for any changes (VB is not installed on my system any longer).
Somehow it still runs on Windows10 (if you keep it local and give itâs folder full permissions for âUsersâ). Usually most problems people have are Windows permission issues (make sure âUsersâ gets full access for the âRayflectar Project Timersâ folder). Other than that, I am not sure how it would behave over networks and such (it wasnât tested like that).
Thanks for using the app, but sorry that I canât be of much more help here.
I just upgraded to a new Win11 computer and was able to install and use the Project timer. The users âfull accessâ thing Thomas mentions above seems to be the trick. Read the read me in the download folder.
