Is there an online rhino 3D viewer?
Wish for a client to view my/his model…easily, no installs etc,
shaded view mode.
also posted at Online Rhino Viewer - #46
Not the most obvious place for such , folk that have found a solution might not be looking there on a regular basis.
Cheers
Steve
Would this work? rview
Or this: https://3dviewer.net/
Also, Irhino has been rewritten for iPad and iPhone: Rhino - iRhino 3D
Did you try google or look at any other topics on this forum?
Hi Steve -
Just to refresh your memory… There is quite a bit of information in your previous thread on this topic:
@scottd , the rview rview works just fine … tried today and can view the lines, rotate … etc.
will save it to my favorities … no need to export … etc. … great add on … Thank You !!!
JACARANDA-PM.3dm (265.1 KB)
I tried to view the attached file that contain only lines in the https://3dviewer.net/ , but it did not take it … it looks like it needs more than lines … 3D objects …
@Pedro_R_Munoz we didn’t create 3dviewer.net but I believe it only supports meshes.
Thank You Morteza … yes I had to create pipes which are 3D solids and then be able to see the solid entities in 3D … appreciate your feedback … Thank You
