Is there an offline .chm documentation available for RhinoCommon SDK?
I am constantly using RhinoCommon SDK as reference when writing codes. However, it can be very inconvenient while working offline or with poor connection. I just wander whether there is a .chm file (or .pdf) available for download to use offline.
Thank you!
will McNeelSep '16
http://developer.rhino3d.com/api/RhinoCommonWin/RhinoCommon.chm21
Greatly appreciated! @Tom_P
This link is not working anymore, do you know if there is a new/working link where I can get hold of the API?
Cheers!
sorry - for the current version i only know about the online documentation
https://developer.rhino3d.com/api/RhinoCommon/html/R_Project_RhinoCommon.htm
but maybe @pascal or @dale are the right persons to ask
you might want to use adobe acrobat “create pdf from webpage” with caputer multi-level feature on same server… not sure if the result is nice. - best - tom
Hi @DavAndLar,
See the following:
RhinoCommon.6.29.20178.9191.zip (17.9 MB)
Note to developers, if you add xml comments to your plug-ins and assemblies, its pretty easy to generate useful documentation using Sandcastle.
– Dale
Thanks for the link. Does Mc Neel teams use this tool for documentation?
I use doxygen then an old Microsoft tool to generate chm.
Hi @laurent_delrieu,
We don’t produce .chms for RhinoCommon (this was an exception). But, we do use Sandcastle to produce the online help for RhinoCommon. The tool is pretty good, but it “does what it does” and we don’t have much control over what it produces. For Rhino 7, we are looking into some alternatives, including rolling our own.
– Dale
Thank you @dale!
Hi @dale
Could I request a RhinoCommon.WIP.chm for the below link? :grinning:
RhinoCommon WIP
Best,
Vincent
https://developer.rhino3d.com/wip/api/RhinoCommon/RhinoCommon.chm
Thank you Will!
thank you very much for the help
