Hi~
My project is a steel structure pavilion, and I found that the structural mass calculated in Karamba differs greatly from the structural mass calculated in Sap2000. I have repeatedly searched for the reason, but cannot find it.
The properties defined for the mid level structural components in Karamba and Sap2000 are the same.
Version of Sap2000:24.2
Version of karamba: 1.3.3
Version of rhino:7.29
Hi, have you checked that the gamma (material density) in Karamba and SAP of all your materials actually match. This can cause discrepencies in your calculations.
However when I check your columns and your braces the weights are basically the same so you should check your mesh.
