Is there a way to turn pen display linework into real linework?
My design is a very complex mesh so make2D does not work very well, but when I set the display mode to pen it shows very clearly. I was wondering if there is a way to take that view and have it become actual 2D linework? Similar to how make2D and ExtractRenderMesh work. I want to be able to add and subtract from this linework to clean it up.
Hi Zac - currently there is no way to get the Pen or other ‘technical’ lines as curves.
This has been on the wish list for as long as technical view has been present (Rhino 4?) and have been discussed many times. With the conclusion that it should be technically possible to convert screenspace of an oversized viewport (like viewcapture does) to worldspace.
For all drawings that are for illustrative use in scale (architecture in 1:100) etc this would be great, and for everything pdf related where the high accuracy of Rhino is discarded or reduced anyway.
I hope this can make it into Rhino in the future.
