Is there a way to select those slanted lines
Is there any way to select curves with slanted angle. pretty helpful do cleanup work of exploded hatch from pdf and other selection work.
_selcolor
_isolate
_selLine
I dont think there is a 45-degree only selection -but it s possible and easy to do with a script…
Hello- here’s a thing you can try - use the ā€˜curve’ option and point it at one of the lines.
SelParallel.py (4.8 KB)
To use the Python script use RunPythonScript, or a macro:
_-RunPythonScript "Full path to py file inside double-quotes"
thanks pascal, this is exactly what i need and even much more than that…
Amazing, i will start learning scripting soon.
