I essentially wish to have a C# or python component that does the following
time_since_last_execution = time_now - time_when_this_component_was_last_executed
time_since_last_execution > 10s:
do_Something()
else:
do_something_else()
The “time_when_this_component_was_last_executed”-part is where I struggle
dale
(Dale Fugier)
2
Hi @Timo_Harboe_Nielsen,
Use the dictionary that is on scriptcontext to store the last time value between executions.
import scriptcontext as sc
import time
def test_time():
current_time = time.time()
print(time.strftime("%H:%M:%S", time.gmtime(current_time)))
if sc.sticky.has_key('last_time'):
last_time = sc.sticky['last_time']
elapsed_time = current_time - last_time
print(time.strftime("%H:%M:%S", time.gmtime(elapsed_time)))
sc.sticky['last_time'] = current_time
test_time()
– Dale
In GHPython one can also use the if “foo” not in globals(): method for making persistent variables. This example should get you going:
