Hello everyone,
I’m just trying to translate a function from python to C# but couldn’t find the best equivalent. I hope I could use your helps in it.
The function time.time() in python to C# equivalent.
with regards,
Mehrzad
Hello everyone,
with regards,
Mehrzad
Thank you Menno for your reply. Actually, I know about the properties of DateTime. But the problem is time.time() in Python counts the time from the first time it runs. As written here:
Two useful functions for time measurement are time.time
and time.clock
. time.time
returns the time in seconds since the epoch, i.e., the point where the time starts.
But DateTime.Now uses that specific time of running the program! So should I just use now as a translated method from Python? or is there any closer?
I suppose it depends on what you want to use the result for.
There are multiple ways to handle dates and time in .NET (C#) - DateTime
is one of them. DateTimeOffset
is another, useful for calculating differences. If you want to time how long an operation takes, there is also the System.Diagnostics.Stopwatch
class. These classes are all documented and a Google search away
Thank you Menno.
If you want the time in seconds since epoch you can use DateTimeOffset.Now.ToUnixTimeSeconds()
