Timer up, Timer Down (w/ Interval control)
Greetings, and sorry for the simple question. After a bunch of searching, I couldn’t quite solve it and I’m still in the early phases of learning C# …
I’d like the attached C# script to have the added functionality of an Interval input, allowing the count speed to be adjusted in ms – as in, for example, the attached Python component found here:
Currently, the script simply counts up to a max value, and counts back down to 0 when reached (and back again) - this is good, but I’d like to slow it down and speed it up without having to overshoot the max and divide the output.
This post has given me a clue as it relates to the above, but I’m a bit stumped on how to bring this into to attached C# component:
Timer_UpDown.gh (7.5 KB)
for reference: 191228_GHPython_Timer_01.gh (5.2 KB)
private void RunScript(bool Run, bool Reset, int Interval, ref object Counter)
    if (Reset)
        _myCounter = 0;
    else if(Run)
        _myCounter++;
        UpdateComponent(Interval);
    Counter = _myCounter;
// <Custom additional code>
int _myCounter = 0;
void UpdateComponent(int interval)
    GrasshopperDocument.ScheduleSolution(interval, doc => Component.ExpireSolution(false));
// </Custom additional code>
InternalTimer.gh (4.9 KB)
This is helpful, and I’m sorry for the confusion. I’m looking to keep the C# script as-is, but add the interval functionality. I only posted the Python version as a reference for what I’d like to add, but I don’t want it to replace the max value input and the counting down once it’s reached.
Sorry I didn’t check the attached file.
private void RunScript(bool reset, bool run, int max, int interval, ref object A)
    if(reset) n = 0;
    else if(run)
        n += increase ? 1 : -1;
        if(n == max || n == 0) increase = !increase;
        UpdateComponent(interval);
    A = n;
bool increase = true;
int n = 0;
InternalTimer.gh (6.6 KB)
Ah, very nice. Thanks!!
Here’s an example for a use for this - for quick animations within the GH environment.
Edit - instability is fixed: “increase” needed to be set back to true when the reset button is pressed to avoid the value going negative if the button is pressed during a decrement.
WavyHyperboloid_v2 animate.gh (23.7 KB)
