Is there a way to Disable Selection Menu?
This is one of those things that is unnecessary annoying of Rhino, no other 3d program has this selection menu and they do just fine with selecting intersecting objects. Honestly it has never been of any use to me, but rather source of frustration.
I just want Rhino to select whatever is on top of the list, and if that is not the object I want I just run Hide till I get the one I want. Or have it cycle across objects with every click. Anything but this menu which forces me to either click it again or press space again to select the first object on the list.
Might not sound like much, but when you are repeating tasks x100 it really throws your workflow off.
Is there a way to disable it? Thanks!
No.
The only reason it comes up is when your pick is ambiguous and Rhino needs more help identifying specifically what you want to select.
You may be able to fine tune your picking by using other viewports and/or the Selection menu.
