CreateRooms.gh (8.5 KB)
Hello. Thank you always.
What I’m trying to do is to create a room boundary using Curve and create a room automatically.
I found a method to implement the function in docs, but I am asking for your help because it is difficult to code.
https://www.rhino3d.com/inside/revit/beta/guides/revit-spatial#modifying-separation-lines
I found an example file on that link that creates a room divider, but it doesn’t work.
Hi! I answered your question partly, I generated spaces from the geometry that you sent, however, I did not use C# or Python. I hope this helps! Here is the video: https://youtu.be/crGGQk_-dtA
