Creating a 3D Convex Hull
Hi all,
I am trying to use Starling and Kangaroo to create a 3D convex hull out of a series of points.
However, the component ‘slHull3d’ is always red with a note saying that “1. Solution exception:Specified argument was out of the range of valid values.Parameter name: index”
I wonder whether there are some rules for arranging the points to make it work?3d convex hull.gh (29.2 KB)
Thanks!
K
Try mesh edit. It has a more up to date 3d hull.
Thanks! and then use Kangaroo to shrink the mesh?
The Grasshopper add-on included with RhinoPolyhedra has a QuickHull component.
– Dale
Hi Dale,
I had installed RhinoPolyhedra a couple of years ago and was unaware there was a GH component. After reading this, I just reinstalled it and still don’t see anything anywhere in GH, just the command in Rhino. What am I missing? I’m using Rhino Version 6 SR12. Thanks.
If you have the latest RhinoPolyhedra installed, from Food4Rhino, then you’ll see this in Grasshopper:
And you’ll see this in Rhino’s plug-in manager:
– Dale
Alright, got it! The first time, I dragged and dropped into Rhino, and restarted, which apparently didn’t take. Thanks.
