Is there a python library, similar to rhinoscriptsyntax, that contains Grasshoper’s components?
For instance Grasshoper has a “4pt surface” (Srf4Pt) component. But I could not find any such function in the rhino python package.
Yes, it‘s called ghpythonlib and you can import it like this for example:
import ghpythonlib.components as ghcomp
You then have access to (almost) all components as functions ![]()
Instead of wrestling with the near obsolete ghpythonlib, you could simply use Rhino.Geometry.NurbsSurface.CreateFromCorners (cf. docs).
In some cases, ‘CreateFromCorners’ appears to be less sensitive to point sequence than Srf4Pt
import Rhino
a = Rhino.Geometry.NurbsSurface.CreateFromCorners(V[0],V[1],V[2],V[3])
Ruled surface component replicates exactly the same behavior as Srf4Pt component:
Rhino.Geometry.NurbsSurface.CreateRuledSurface
Or more sensitive?
Less sensitive in the sense that a correct result is less dependent on the sequence of points.
