Is there a way to add multiple edgeloops? The insert edgeloop command only does one at a time. More importantly, is there a place where all the SubD commands are listed with the modifiers?
i just know this source
its a bit of a workaround, buy you can delete a row of faces, then use bridge to put them back with multiple edge loops.
It’s a little less efficient. It should have better and more direct support for inserting multiple edges
That works, but Xkdsofa is correct.
agreed-
It’s on the list-
