Is it possible to remove all the point using the “grasshopper”?
can “grasshopper” remove an arbitrary number of points?? how to do this??
точки.3dm (250.4 KB)
Hello @Joseph_Oster , Thanks for the answer, I couldn’t imagine it. I can’t find the element “yellow list of elements”
my example
Hi @timob2567 ,
Are you looking for the Panel ?
You can search for “Panel” with a double click search in the canvas
Type // and then text to create a panel.
Hope that helps!
Hello @Joseph_Oster , Thanks , I can’t add items to the “panel”.
How to add elements to the “panel”, is it possible for the “grasshopper” itself to add elements to the “panel”?
Apparently you don’t know how to “import” Rhino geometry using ‘Params’ components ![]()
Sorry for interrupting again @Joseph_Oster ,
for some reason “grasshopper” does not define points ![]()
using the “Bake” command
but nothing happens ;_;
it marks points but does not delete them
I can’t see what you are doing but any problem here is almost certainly user error.
Don’t bake everything like that. Select the node with the points only and choose bake. Else upload your code because it’s really hard to understand what the issue is.
Oke @Ftzuk
trying, not work ;_;
точки_снова.3dm (58.5 KB)
точки_удалить_ вторая_ревизия1.gh (11.0 KB)
It does. If you bake the points they appear in Rhino.
hello , @Ftzuk
I click “bake” but it doesn’t delete point. And also does not highlight them.
when I select points it highlights them in green.
Bake is to create points, not delete them.
tsank @Ftzuk Is it possible to remove all the point using the “grasshopper”?
You can’t delete with Grasshopper.
Why don’t you just select the points in Rhino and delete them? I don’t really understand why you need grasshopper for this.
Hi @timob2567 ,
Like others, I’m confused why you need to automate this process but suspending those questions here’s a solution for GH (R8) that will get the GUIDs of Point objects in your Rhino Model and delete them when you press the Delete button in the GH script.
Graph Space (Before Pushing Delete):
Graph Space (After Pushing Delete):
Model Space (Before Pushing Delete):
Model Space (After Pushing Delete):
Hope that helps you!
20240704_точки_удалить_ вторая_ревизия1_Response_01a.gh (13.4 KB)
Or just this:
I totally forgot this is a new feature of the updated cache component haha. Thanks!
Hello @Volker_Rakow
I searched the entire “grasshopper” and did not find this element.
Tell me please, his name.
