Is It Possible to Preserve 1-Bit Bitmaps? (Import/Export)
I’m looking to import 1-bit bitmap images into Rhino and export them without any loss, meaning preserving the strict 1-bit black and white format — no grayscale or anti-aliasing.
This is important in fields like offset printing, where file size and precise tone reproduction are critical.
When importing a 1-bit image using the _Picture command, does Rhino preserve the original 1-bit format internally?
If Yes on export, I haven’t been able to generate PDFs that maintain the 1-bit bitmap format. Is there any way to export a file (e.g., as a PDF/X-4 or similar) that preserves the 1-bit data, potentially allowing high-resolution output (like 1200 or 2400 dpi) without converting it to grayscale?
Also, is it possible to use a custom RIP or driver within Rhino to preserve this kind of data? On Mac or Windows?
Bitmap.3dm (6.4 MB)
PDF from Rhino
RhinoPDF.pdf (2.2 MB)
PDF X-4 from Illustrator (same .bmp as in Rhino)
AIPDFX4.pdf (812.1 KB)
Thanks in advance!
Best,
Pip
Does this do what you need?
That’s nice, at least for the display within Rhino. Thanks!
However, the export still doesn’t seem to work properly. I tried exporting as a bitmap, but it’s not a 1-bit bitmap when opened in Photoshop. It would be great to have the option to export a clean 1-bit bitmap directly from Rhino. Even better would be if Rhino could preserve the original image file format when compiling a PDF with vector output.
