Hi everyone! I wonder that if I can listen to explode event specifically? Or it is only possible to listen remove and add Object events caused by the explode operation? Thanks.
not sure 100% but i think this is the starting-point:
did you try to subscribe to …?
https://developer.rhino3d.com/api/RhinoCommon/html/Events_T_Rhino_Commands_Command.htm
remember RuntimeSerialNumber if command is explode before the command
if the last englisch command name was explode…
the result was sucess…
check for new objects with RuntimeSerialNumber
kind regards -tom
Hi @Tom_ ! Thanks for the answer. I managed to listen to explode event with your directives. Here is the configuration:
Added following line to OnIdle:
Rhino.Commands.Command.BeginCommand += csEventHandler.onBeginCommand;
onBeginCommand function:
internal static void onBeginCommand(object sender, CommandEventArgs e)
if(e.CommandEnglishName == "Explode")
// do before explode ..
