Hello everyone,
I want to translate this pythonscript code into rhinocommon:
import scriptcontext as sc
import Rhino as r
sc.doc = r.RhinoDoc.ActiveDoc
Plane = sc.doc.Views.ActiveView.ActiveViewport.ConstructionPlane()
height = 2
font = "Arial"
text = "Sample Text"
preText = rs.AddText(text, Plane, height, font, False, False)
textGeo = rs.ExplodeText(preText, True)
Here are the code that I wrote in C#:
string text = "Smample Text";
Rhino.Geometry.Plane plane = doc.Views.ActiveView.ActiveViewport.ConstructionPlane();
double height = 10;
string font = "Arial";
doc.Objects.AddText(text, plane, height, font, false, false);
return Result.Success;
But I can’t figure out how to explode the text object.
dale
(Dale Fugier)
February 2, 2017, 7:15pm
2
Hi Mahdiyar,
The source code to rhinoscriptsyntax can be found on your system in this folder:
%APPDATA%\McNeel\Rhinoceros\6.0\Plug-ins\IronPython (814d908a-e25c-493d-97e9-ee3861957f49)\settings\lib\rhinoscript
In this folder you will find a geometry.py file that contains the definition of rs.ExplodeText, which appears to be calling RhinoObject.Geometry.Explode().
Does this help?
– Dale
Hi, Dale.
Thank you for your reply, Sorry for my silly question, but I can’t find [Explode].
dale
(Dale Fugier)
February 2, 2017, 9:01pm
4
Hi Mahdiyar,
You need to do some object casting to get this to work correctly:
var str = "Hello Rhino!";
var plane = Rhino.Geometry.Plane.WorldXY;
var obj_id = doc.Objects.AddText(str, plane, 10, "Arial", false, false);
if (obj_id != Guid.Empty)
var obj = doc.Objects.Find(obj_id);
if (null != obj)
var text = obj.Geometry as Rhino.Geometry.TextEntity;
if (null != text)
var curves = text.Explode();
foreach (var crv in curves)
doc.Objects.AddCurve(crv);
doc.Objects.Delete(obj, true);
doc.Views.Redraw();
– Dale
Hi again and thank you. It works perfect.
