Hello Please let me know if there is an API that can control the check / uncheck of Clipping Plane in Display mode as shown above. I would appreciate it if you could show me an example too.
Yes, you should be able to do it like this (I modified another sample from RhinoCommon doc. online to turn off clippingplane display for selected displaymode):
https://developer.rhino3d.com/api/RhinoCommon/html/P_Rhino_Display_DisplayModeDescription_DisplayAttributes.htm
import Rhino
import scriptcontext
# The following example demonstrates how to modify advanced display settings
# using RhinoCommon.
def AdvancedDisplay():
# Use the display attributes manager to build a list of display modes.
# Note, these are copies of the originals...
display_modes = Rhino.Display.DisplayModeDescription.GetDisplayModes()
if not display_modes: return Rhino.Commands.Result.Failure
# Construct an options picker so the user can pick which
# display mode they want modified
go = Rhino.Input.Custom.GetOption()
go.SetCommandPrompt("Display mode to modify mesh thickness")
opt_list = []
for i, mode in enumerate(display_modes):
english_name = mode.EnglishName
english_name = english_name.translate(None, "_ -,.")
opt_list.append( go.AddOption(english_name) )
# Get the command option
go.Get()
if go.CommandResult()!=Rhino.Commands.Result.Success:
return go.CommandResult();
selected_index = go.Option().Index
selected_description = None
for i,option in enumerate(opt_list):
if option==selected_index:
selected_description = display_modes[i]
break
# Validate...
if not selected_description: return Rhino.Commands.Result.Failure
# Modify the desired display mode to turn off ClippingPlanes display
selected_description.DisplayAttributes.ShowClippingPlanes = False
# Use the display attributes manager to update the display mode.
Rhino.Display.DisplayModeDescription.UpdateDisplayMode(selected_description)
# Force the document to regenerate.
scriptcontext.doc.Views.Redraw()
return Rhino.Commands.Result.Success
if __name__=="__main__":
AdvancedDisplay()
below is a simple toggle for the current vievport display mode, works in V6 only:
import Rhino
def DisplayModeToggleClippingPlanes():
if Rhino.RhinoApp.ExeVersion < 6: return
dmd = scriptcontext.doc.Views.ActiveView.ActiveViewport.DisplayMode
state = dmd.DisplayAttributes.ShowClippingPlanes
dmd.DisplayAttributes.ShowClippingPlanes = not state
Rhino.Display.DisplayModeDescription.UpdateDisplayMode(dmd)
_
c.
