Hi all,
Does anyone know if there is a way via python scripting to turn off the “show edges” option from the Display - clipping plane settings from all viewports ?
Many thanks in advance
Hi all,
It is quite simple in RhinoScript but I am not familiar with a way to do it in Python. I don’t think RhinoscriptSyntax has the method for it, so it would need to be RhinoCommon.
Keep in mind the setting is per-display mode, not per-viewport, so you would need to determine display mode for each viewport and operate on these.
A hacky way to do it from Python would be to run Rhino.Command("-_Runscript [put a Rhinoscript that does it here]"), but there is probably a better way, plus the hack would be a windows-only…
–jarek
Hi @revink,
The setting you show is just a shortcut to this:
This setting is not available in RhinoCommon. Thus, it’s not available in Python. I’ve added it to the to-do pile.
https://mcneel.myjetbrains.com/youtrack/issue/RH-53067
– Dale
If RhinoScriptSyntax was in-sync with RhinoScript, this method does it:
@piac - is this still a project of yours?
Is there a plan to at some point keep these two synchronized as close as possible (I know some things on each end don’t make sense, but general universal methods, at least?)
thanks,
–jarek
